alignment specs for my 99 miata?
  • alignment specs for my 99 miata?
    Well, after reading about 40 different alignment post on 3 different miata websites, im still not sure on what to set it to. My car is a track/daily driver si cant have the tires wear out too quick. My set up; tein flex coilovers (front 10k rear 6k), Flying miata, sways (front stiff, rear soft) and i run 200/580/15 dunlop sp tires. Any help would be great, thanks.
    99 miata-tein flex, RB sway bars
    streets cw 1:27.1
    Streets ccw 1:25.4
    Htm cw 1:01.8
    big willow 1:28.8
    Bw13 cw 2:00.8
    2006 miata daily
    Big willow 1:35.08
    Miata Race alignment
    Use the first setting for less aggressive alignment.
      This is the best of what I have found on the Internet, which includes what William posted.
      JD’s Setup Guide for Spec Miatas (from Specmiata.com)
      Front
      Toe: zero front and rear
      Camber: -2
      Caster Front: +3-5, equal on both sides
      Rear
      Camber: -2
      Ride height: 5 ¼ inches from pinch weld to the ground
      Cross weight: 50 percent front and rear
      Settings done with sway bars disconnected on left side, tires at 40 psi and driver’s weight in the car, 230 pounds.
      949 Racing Specs (from 949racing.com)
      For Miatas between 13” - 12" front ride height
 (hub center to lip of wheel opening)
      Front
      Camber: -2 degrees (or as close as you can get to it)
      Caster: +3.75 to +4.25*
      Toe: 0
      Rear
      Camber : -1.8 degrees
      Toe: 0
      Icehawk’s Alignment (from Google search)
      Front
      Caster: Maximum
      Camber: -1.5°
      Toe: out 1/16" per side
Rear
      Camber: -2°
      Toe: in 1/16" per side
      Lanny’s Alignment (from Google search)
      Front
      Camber: -1.2 degrees
      Caster: 5.0 degrees
      Toe: 1/32 inch in per side
      Rear
      Camber: -1.75 degrees
      Toe: 1/32 inch (0°4.5' or 0.075°) in per side
        Problem with last 2 alignment. Is rear has more camber than front.
          From what I understand, Lanny's and Icehawk's are autocross alignments.
            Good advice above. But if you're in SoCal just take it to West End and tell Darrin everything you said here and he'll know what's good for you...
            Edit: On second though, after seeing you write "tires wear out too quick", if by any chance your car is "hellaflush" or looks like below, you have bigger problems than tires wearing out too quick
              lmao! ill post pics in a bit
              streets cw 1:27.1
              Streets ccw 1:25.4
              Htm cw 1:01.8
              big willow 1:28.8
              Bw13 cw 2:00.8
              2006 miata daily
              Big willow 1:35.08
                These are my track wheels, 15x7 forged centerlines. car sits lower now.
                and these are my street wheels, oem 15" bbs's
                and here is my $800 beater back up car
                streets cw 1:27.1
                Streets ccw 1:25.4
                Htm cw 1:01.8
                big willow 1:28.8
                Bw13 cw 2:00.8
                2006 miata daily
                Big willow 1:35.08
                  That's a pretty nice "beater." Mariner blue didn't sell well, but I always thought it was cool.
                    i really did pay 800 for it. One owner in good running condition. It has rust (she brought it from the east coast) but its not too bad.
                    Thanks for the help guys, i just finished up the torsen swap today so ill be getting it aligned tomorrow or next week.
                    streets cw 1:27.1
                    Streets ccw 1:25.4
                    Htm cw 1:01.8
                    big willow 1:28.8
                    Bw13 cw 2:00.8
                    2006 miata daily
                    Big willow 1:35.08
