Help me sort out my Miata's suspension!
  • Help me sort out my Miata's suspension!
    So here's my dilemma. I'm currently running the Tokico HP springs/shocks along with a 1" front FM sway bar on the soft setting with the stock rear bar. The suspension proved to be far too soft at ACR on Sunday as I was rubbing on the unibody on the front two wheels in nearly every corner. Let me make this clear, it's not rubbing on the fenders or the shock towers, so it's not a problem with my wheel's offset (15x7 +30 Team Dynamics). Before the plan was to get a set of Koni Yellow's re-valved to SPSS3 and run H&R Race springs on them. I've heard from some that they are too soft though, so now I want to know what springs I should run with Koni Yellow SPSS3 for a good track setup. I'm not worried about comfort on the street. Thanks for the help
    I think you are just rubbing on the front fender liners, a common Miata thing.
    common setup is 9kg/6kg (street). or 12/7kg stiff setup (track). I think Koni yellow barely have enough damping for 9/6kg, probably less.
    I would also run front FM sway at stiffest setting. many track Miata runs w/o any rear bar.
      I have my fender liners in the front out. Trust me, there is polished metal under there I'm getting very mild understeer with my current setup, but things should change when I change the springs. Are there any springs out there at those rates? And if Yellow's aren't enough for those kinds of rates, than what is (besides coilovers)?
        Oh and I forgot to mention, the Koni Yellows I'm getting are re-valved to SPSS3 spec. That should be enough shock for any spring I could ever throw on there right?
        Edit: So a 65mm / 10kg / 6IN spring in the front and a 65mm / 6kg / 190mm spring in the rear would be fine right?
          sorry, not familiar with SPSS3. that's more of auto-x valving.
          10/6kg is fine. about the right balance. and ride decently for a street/track car.
          15x7 is also been out of fashion for a while we all run 15x9, may be a few run 15x8
          may be Emilio of 949racing will chime in. he is the Miata king.
            I'm running 15x7 with the Kuhmo XS in order to fit into Street Class for the Miata Challenge for the final round. They worked great at ACR.
              Isn't Savington running Koni Race shocks with Ground Control sleeves? Not sure what rates he's running but he seems to make it work.
              e
                e
                He ran Xida's for SLB and RTA. He was not happy with his 700/450 Koni Race setup so I offered to loan him the protos off the OGK.
                bedheadben,
                What are your spring rates?
                OEM upper shock mounts and bumpstops?
                Occasional rubbing of the shock towers at full compression is normal on big hits. If its doing it continuously, your springs are way too soft. The OEM suspension has tiny wheel rates to give a decent ride, then rides on the bump stops in hard cornering. When the car is lowered the typical 1-2", the roll center is lowered more than the ride height. This increases the leverage the CG has on the roll centers so roll stiffness is reduced. This is why a fast track Miata needs spring rates on the order of 4x that of OEM to handle any bumps well at over 1G lateral acceleration.
                Translation: You probably need much stiffer springs or to raise the car up.
                  Thanks for the help Emilio. The spring rates are 233lbs front and 138lbs rear. This is what I ran in the Miata Challenge on Sunday. Like I said though, I have some revalved Koni's coming in the mail along with a 65mm / 10kg / 6IN spring in the front and a 65mm / 6kg / 190mm spring in the rear which will hopefully fit.
                  Edit: And yes I'm running OEM upper shock mounts and bump stops. I was thinking of getting some mounts for the rear at least to increase travel a bit.
                    NB mounts with pieces to adapt to the NA shocks are a good idea. FCM has a complete NB hat conversion kit that is proven to work very well.
                      Yep. Put your new springs in. 233lbs front and 138 rear is pretty darned soft.
                      Or here's a better idea, throw away that girlie car and buy an S2000 so you can earn the respect of metrosexuals everywhere.
                      Please, no guesses or claims as to who I am in public.
                        He's baaaack!!!
                          Louieeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
                          Do you understand?
                            Hahaha, got my springs in today, I'll hopefully be putting them on pretty soon.
                              [YOUTUBE]http://www.youtube.com/watch?v=cec1JInytH0[/YOUTUBE]
